throwing codes 42 and 43
Old Nov 11, 2009 | 08:49 PM
polaris91's Avatar
Car: 88 camaro z28
hi i have an 88 camaro with the 305 tbi and i am continueously throwing codes 42 and 43 i adjusted my timing which was advanced by like 4 degrees and the check engine light comes on less often now it usualy comes on if i accelerate hard does anyone know what could cause these?
thanks
Old Nov 11, 2009 | 08:53 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: throwing codes 42 and 43
est(electronic spark timing) is probably gettin false signals from the knock sensor if its bad. or your knock sensor is probably unplugged.
Old Nov 11, 2009 | 09:00 PM
polaris91's Avatar
Car: 88 camaro z28
where is the knock sensor located?
Old Nov 11, 2009 | 09:02 PM
Engine: 383 hsr
on the side of the engine block, right above the starter. its a one wire connector. those connectors are known for falling off or breaking easily when working around it.
Old Nov 11, 2009 | 09:08 PM
polaris91's Avatar
Car: 88 camaro z28
ok thanks alot is this somthing that would be expencive to replace?
Old Nov 16, 2009 | 07:00 PM
Engine: 383 hsr
no, pretty cheap. if its the connector, you could get one off a junk yard one, or rig it to stay on. if the knock sensor is bad, just get one at a parts store (idk how much, should be cheap).
Old Nov 16, 2009 | 07:46 PM
polaris91's Avatar
Car: 88 camaro z28
cool thanks alot how long will it take for it to register if its fixed?
Old Nov 16, 2009 | 07:51 PM
Engine: 383 hsr
as in plugging it back in?, imediatly. well, actually when it warms up at around the time when the esc should retard it. and if your codes dont come back after cleared.
Old Jun 16, 2010 | 06:25 PM
fubar_1179's Avatar
Car: 89 Camaro RS Coupe
Engine: 305 TBI
Axle/Gears: Stock I Guess
Just wanted to say, i got the 42 code. What fixed mine was replacing the distributor. 100bucks but well worth it. Car runs 100% better. Corrosion was on the sensors when i took the cap off. I guess it got a little wet somehow.
Fanatic1074
Oct 3, 2022 05:57 AM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
Bigold4x4
Sep 28, 2015 05:21 PM
ndndndnd
Sep 28, 2015 08:00 AM
