TBI--power to injectors
Old Sep 12, 2010 | 08:55 AM
zact1024's Avatar
Car: 88 Camaro
Engine: 305 TBI
If you are not seeing power to injectors what is the step by step process find the problem on a tbi with vats?
Old Sep 12, 2010 | 06:40 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: TBI--power to injectors
If the ignition circuit has not been changed, and the starter turns, then it should not be a VATS issue. Is this on the 1988? Because I thought VATS didn't start until 1989.
Old Sep 12, 2010 | 06:47 PM
zact1024's Avatar
Car: 88 Camaro
Engine: 305 TBI
no a 91 i just never changed my car in the screen name thing
Old Sep 14, 2010 | 05:38 PM
zact1024's Avatar
Car: 88 Camaro
Engine: 305 TBI
Checked it and I am getting close to 12v on the "A" side of each injector harness, but nothing on the b side. What do I do now? And what would be the most likely cause of this?
Old Sep 14, 2010 | 08:17 PM
zact1024's Avatar
Car: 88 Camaro
Engine: 305 TBI
maybe it could be my ignition control module? I did recently drop my distributor in the driveway and it is severely rusted everywhere..gonna go to autozone tomorrow and get it tested..in the meantime, what else should I look for? Anything will help
Old Sep 16, 2010 | 07:43 PM
zact1024's Avatar
Car: 88 Camaro
Engine: 305 TBI
ok wasnt icm..now what do i look for? does no one really not know what to do?
Old Sep 20, 2010 | 09:49 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Injection Perfection
Disconnect the 4 pin connector at the distributor.
Disconnect both injectors.
Connect a test light
(the type for testing for voltage, not a continuity tester) across one of the injector connectors.
Put the key in the RUN position.
Using power thru a small light bulb, such as a side marker, probe the purple/white wire on and off with the probe.
Does the injector test light blink?
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
