what is this?
Old Sep 17, 2010 | 06:20 PM
RussC's Avatar
what is this?
just woundering what this module might be, its located in the drivers side kick panel, 4 wires going to it.
Old Sep 18, 2010 | 01:43 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: what is this?
Hello RussC!!
Vats?????
Is your car 1989 or newer???
What colour are the wires????
Old Sep 18, 2010 | 03:30 PM
RussC's Avatar
Re: what is this?
its a 1989 and the colors are green wight stripe, green, yellow white stripe, and yellow. 2 thick wires the ones with the stripe, are on the outside at each end.
Old Sep 18, 2010 | 04:34 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Re: what is this?
is not the vats ....
if not mistaken its the starter enable relay (usually wrapped around with electrical tape)
Old Sep 18, 2010 | 05:03 PM
Re: what is this?
Hello juanillox8!!
Isn't the starter enable relay, parts of the VATS system???
By the way you are right, it is the starter enable relay, I just didn't have the right "terminology" at my finger tips, so I didn't call it anything, but rather pointed to the right system, VATS!!!
Old Sep 18, 2010 | 05:24 PM
Twin_Turbo's Avatar
Re: what is this?
power door locks
Old Sep 18, 2010 | 05:46 PM
RussC's Avatar
Re: what is this?
thanks for the help
Old Sep 19, 2010 | 10:58 AM
Pocket's Avatar
Car: 91 Trans Am
Re: what is this?
Starter relay, and yes, it's part of the VATS system
http://www.austinthirdgen.org/mkport...nE_starter.jpg
Old Sep 19, 2010 | 12:20 PM
Re: what is this?
Thanks Pocket!!!
Old Sep 19, 2010 | 12:46 PM
juanillox8's Avatar
Car: TOO MANY
Re: what is this?
Originally Posted by 87IROC-DAN61
Hello juanillox8!!
Lol yea but usually when some one says vats the module comes to mind. Kinda like saying ignition theres many things that are in that system but usually the switch comes to mind
Old Sep 19, 2010 | 02:05 PM
Re: what is this?
Hello juanillox8!!
That's why I used the ??????? after VATS!!!!
