how to bypass my VSS?
Old Sep 29, 2010 | 10:44 PM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
I did an LS1 swap and my speedo doesnt work. I know the computer is getting and outputting a speed because I have a scan gauge mounted in my car that reads the OBDII port.
I figured I could bypass the chassis wiring and wire the VVS straight to the back of the speedometer. When I did that however the guage worked (immediately going to 140 when I revved it) but I lost the speed coming out of the OBDII port.
I bypassed it by running one of the VVS wires to the signal, not ignition side of the speedometer. Do I need to run a wire from the output of the computer to the back of the speedometer?
I just want my factory gauges to work, thanks for the help!
Old Oct 1, 2010 | 06:14 PM
Pocket's Avatar
Car: 91 Trans Am
Re: how to bypass my VSS?
If the car was V6 or TPI, connect the speedo output from the PCM (R50) to C207 pin D (gry)
If the car was TBI, then connect it to C207 pin K (brn) and bypass the buffer box by connected pins C and F
Should work fine now. Be sure your PCM has the proper conversion factor for your rear end gearing and tire diameter
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Formula8r89
Sep 22, 2015 04:24 PM
