Help Installing/wiring gauges?
Old Oct 3, 2010 | 01:39 PM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
So i bought some gauges i plan to mount on the side but this is my first time hooking any up and im wondering where im supposed to hook them up 2?
I have an Oil psi, volt and Temp gauge i want to install.
Can anyone help me out with this?
Old Oct 3, 2010 | 08:15 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Help Installing/wiring gauges?
should be pretty straightforward. I assume your gauges came with instructions and their own sending units, because they wont work with the factory senders. The oil pressure will hook up to the little port on the back of the block, near the distributor, the water temp on the drivers side of the engine, on the head between the #1 and #3 plugs, and the volts will be a matter of wiring into the electrical off the battery and alternator.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
