Cruise Switch to Harness Wiring
Old Oct 3, 2010 | 04:06 PM
Coolball's Avatar
Car: 82' Z28
Engine: 5.7L 350
Transmission: ST10
Asking advice on this before it gets soldered and shrink wrapped. Car is an 82' Z28 manual. I bought a new cruise switch for the restoration and it came with a short 4-wire 20ga. harness out of the switch but the column harness only has three wires, a brown, a blue and a black. The switch wires are red, yellow, blue and green. Can anyone tell me what wires get hooked together between the two?
From what I can figure on the switch after metering it, green is the common, red is the set switch, yellow is the resume and blue is the feed. What I can't figure out is how does the set switch break (and what) the circuit in this configuration or did I just plain order the wrong switch? Thanks for any help!
Old Oct 8, 2010 | 11:16 PM
Coolball's Avatar
Car: 82' Z28
Engine: 5.7L 350
Transmission: ST10
Re: Cruise Switch to Harness Wiring
Anyone?? I've been searching for the answer for a week and still at a dead end on this. Hoping to get the column back together and in the car this weekend so I can move onto the next of umpteen projects left on it.
Old Oct 9, 2010 | 02:16 AM
Drew's Avatar
Old Oct 9, 2010 | 10:42 AM
Coolball's Avatar
Car: 82' Z28
Engine: 5.7L 350
Transmission: ST10
Thanks for the post Drew. I must have ordered the wrong switch. The switch that was in there also had the same 4 wires but they were all chopped so no reference there maybe it had been replaced with the wrong one originally. Here's what my book shows which is a little different.
Brown on my harness is the 12+ so what it's looking like is
Harness Brown wire to Blue on switch (for 12+ common)
Harness Blue wire to Green on switch (for On)
Harness Black wire to Yellow on switch (for Resume)
And then?? Red on switch to Black for set?
Old Oct 9, 2010 | 12:47 PM
Drew's Avatar
The diagram I posted if from the 1987 manual and might not be correct for earlier cars... I know GM changed the cruise control about 3 times between 82-92. I'd trust the manual for your car above all others. You should be able to test the switch with a DVOM and figure out if it's correct.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
