please help no spark
Old Oct 12, 2010 | 01:24 PM
shatterme18's Avatar
Car: 1985 chevy camaro
Engine: 2.8 v6
Transmission: 700r4 w/ corvette servo
i have a 1989 camaro with the 2.8 ok well car sat for a few months and battery went dead replaced battery and the car had good fire and everything then all of a sudden no spark what so ever but car turns over fine i have new distrutor, wires, rotor, cap, coil, module, plugs just no spark please help thanks
Old Oct 12, 2010 | 01:35 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Spark Is Dark
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe the primary of the coil when the key is in the RUN position.
Is there power?
If no, there is a bad or burned out connection between it and the ignition switch, or power to the switch.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Oct 12, 2010 | 02:25 PM
Engine: 2.8 v6
Re: Spark Is Dark
yes there is power to it
Old Oct 12, 2010 | 02:35 PM
NINÅ's Avatar
Transmission: 765R4
Spark Is Dark
Make sure the coil has a good ground, then: disconnect the 4 terminal connector at the distributor.
Crank the engine while testing for spark.
Is there spark when you try that?
Happy Racing!
Old Oct 14, 2010 | 12:07 PM
Engine: 2.8 v6
Re: Spark Is Dark
are you talking about the connector next to the one with only two wires that we texted first and if so then no i dont have any spark
Old Oct 14, 2010 | 02:12 PM
NINÅ's Avatar
Transmission: 765R4
Spark Is Dark
Yes that’s the one.
OK if there was no spark with that 4 pin connector removed, remove the distributor cap.
Then unplug the pickup coil from the module.
Now connect a voltmeter to the tach terminal.
Turn the key to RUN.
Using a 5 volt power supply with a small bulb in series, touch 5 volts to the innermost pin
(it’s labeled P on some brands) of the module.
Now, does the voltmeter sharply decrease when you touch the 5 volts to the module?
If there is no response from the module it’s bad or not grounded.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Oct 14, 2010 | 03:15 PM
Engine: 2.8 v6
Re: Spark Is Dark
my bad i checked for voltage on the four wires and there was none but i need to check for spark then
Old Oct 15, 2010 | 11:13 AM
Fastcar92's Avatar
Car: 91 RS Camaro
Transmission: 5 Speed
Axle/Gears: 3:08
Re: please help no spark
I kind of have the same problem, I was driving along when my 91 RS camaro just shut off, I replaced the coil, moduel, rotor and cap but still no spark. I have no test equipment to test, It turns over just fine but no spark, could it be the Ignition ( the key part?)
Old Oct 15, 2010 | 11:19 AM
watson90z's Avatar
Car: 1990 iroc-z
Engine: 350 tpi
Axle/Gears: 3.23 posi
try the pickup coil in the distributor my buddies iroc had the same problem just up and stopped running ended up being that
Old Oct 15, 2010 | 11:47 AM
Stephen's Avatar
Car: 87 GTA
Ditto!
After changing, cap/rotor/ignition module/coil....It was the pick-up inside the dizzy.
I just had that happen last week & fixed it on Monday.
Old Oct 15, 2010 | 12:39 PM
Engine: 2.8 v6
i have brand new distributor with new pick up coil
Old Oct 15, 2010 | 07:49 PM
Fastcar92's Avatar
Car: 91 RS Camaro
Axle/Gears: 3:08
well I tried 3 of those pick ups and nothin
Old Oct 17, 2010 | 01:32 AM
Engine: 2.8 v6
Re: Spark Is Dark
where do you get a five volt power supply from
Old Oct 17, 2010 | 02:59 AM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
Re: Spark Is Dark
How are you checking for spark?
Old Oct 17, 2010 | 10:17 AM
Fastcar92's Avatar
Car: 91 RS Camaro
Axle/Gears: 3:08
Re: Spark Is Dark
I dont have one, I checked the spark by putin a screw driver in the plug wire hole and puttin it by metal
Old Oct 17, 2010 | 12:26 PM
Engine: 2.8 v6
i have one of those tools the go between the plug and wire and lights up if spark also used screw driver idea firs
Old Oct 17, 2010 | 06:40 PM
DreadLord757's Avatar
Ok I have the same problem with my 85 Berlinetta 2.8 . It has 16v from the ignition coil to the distributor. and no spark at the distributor to the spark plugs. I disconnected the 4-pin connector from the module connected to the distributor and I get spark and engine almost started, However there is smoke comming from the engine when I try to start it. (might be a different problem)
What exactly is the electronic part that is connected to the distributer and what did I unplug from it? what does that 4-pin connector go to?
Old Oct 18, 2010 | 09:34 AM
NINÅ's Avatar
Transmission: 765R4
Spark Is Dark
You can connect three ‘D’ cell batteries in series.
That will provide 4œ volts which is enuff to do the test.
If you know how to solder you can solder them in series.
If you don’t know how to solder you can go to an electronics parts store and get a battery holder.
Happy Racing!
Make Noise, Turn Left, Repeat
Old Oct 18, 2010 | 04:21 PM
Engine: 2.8 v6
Re: Spark Is Dark
ok thanks i will give it a shot
Old Oct 20, 2010 | 08:34 AM
Ok, I was able to find the solution to my issue thank you. The distributor was not fully mounted down and the electronic component on the distributor was faulty. Replaced mounted and good to go
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
