What are these cables?
Old Oct 13, 2010 | 05:48 PM
BillyTheGoat's Avatar
Car: 1989 Trans am
My car was getting no spark so I checked all the connections and I found some two wires taped on to some grey plastic connection that weren't touching properly. I reconnected them and I got spark again.
It looks like those two wires, or at least one of them since I only traced one, goes to the Distributor cap. Both wires are red, the black one on the pic is just a black wire taped on to a red one.
Also on the second pic, the red wire is taped on to another wire that connects to the distributor cap. Is there a name fore those wires that connect to the Distributor cap and to the grey connection?
To me it seems that those two should connect from the distributor cap to the grey connection and snap on to it.
Another thing, on the distributor cap, is that the ignition module on the top of it? ( 3rd pic)
Attached Thumbnails What are these cables?-disconnected-wires.jpg   What are these cables?-messed-up-wires.jpg   What are these cables?-distributor-cap.jpg
Old Oct 13, 2010 | 07:23 PM
Car: 1989 Trans am
Re: What are these cables?
Alright, after looking at connectors on rockauto, I found out what the grey connector is. It's the ignition coil connector. This fits the no spark I had.
Where is the ignition coil, is it the thing on the top of the distributor? or is it at the end of the ignition coil connector? I tried following the ignition coil connector wires, but they go into the black wire cover
Also what should be connected to the ignition coil, I want to buy the connections to it that would snap on
If anyone needs the info on it heres the part number ACDELCO Part # PT2302
Old Oct 13, 2010 | 07:35 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Your vehicle, or at least your wiring harness, was built for an external coil HEI distributor. The gray connector would go to the external coil. Someone has done a poor job of swapping over to internal coil HEI. The coil is in the top of the cap. Thats why its so large. If you want to properly connect the new dist, You can either use an insulated female blade connector. Or find the OE style single wire connector that locks into the cap. Attach the connector you choose to the pink wire.
Old Oct 13, 2010 | 07:47 PM
Car: 1989 Trans am
That's what I want to do, I was just wondering if there was a specific name for it. And yeah, who ever put those wires did a horrible job, but that bad job cut the price of my car in half since it wasn't running
Do you know where the connector goes to, besides the external coil. I couldn't follow it all the way unless I took of the wire cover
Old Oct 13, 2010 | 10:50 PM
Pocket's Avatar
Car: 91 Trans Am
Pink wire is the main IGN feed directly from your IGN switch
White wire is tach signal directly to your gauge
Old Oct 14, 2010 | 10:43 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Yeah, I spaced the white wire. Youll want to put an insulated blade connector on it too and connect it to the "TACH" terminal at the cap, right next to the "BATT" terminal where the pink wire connects. Again, if you want it to be really sani, you can find the locking OE style connectors.
Old Oct 14, 2010 | 12:52 PM
Car: 1989 Trans am
Yeah I saw the "tach" on the cap, I've been trying to look for the OE style connectors, but no luck yet.
Old Oct 14, 2010 | 12:54 PM
Car: 1989 Trans am
Hey pocket, Do you know where I can find the correct wires for it? or atleast better wires, the ones that are on right now don't work. A slight movement and they become disconnected
Old Oct 14, 2010 | 01:04 PM
Drew's Avatar
Jegs, Summit, Pico, etc... Accel sells a plug with both the power and tach wires. Or you can get the stock style plugs. Google 5664pt and 5663pt, (Pico part numbers) and click the shopping tab.
Old Oct 14, 2010 | 01:46 PM
Car: 1989 Trans am
thanks Drew
Old Oct 14, 2010 | 02:13 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
better idea, get an exteral coil and non in-cap HEI dizzy from a bone yard
Old Oct 14, 2010 | 03:41 PM
Drew's Avatar
Since someone did away with the computer controlled distributor and installed a vacuum advance unit, I'd be willing to bet the car is carbed now... In which case the distributor that came stock in the car wouldn't work anyway.
Old Oct 14, 2010 | 04:00 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Thats correct. Theres no way a computer controlled carb or EFI could work with that dist. It must be carbed and no EST dist will work on it.
Old Oct 14, 2010 | 04:22 PM
Car: 1989 Trans am
yeah its carbed. I got another problem though, I drove the car around the block and after I got back, smoke was coming from the side of the engine (passenger side). It looks like an exhaust leak, but it was alot of smoke and it kept going after the car was off. I guess this will be for another thread though
Old Oct 18, 2010 | 05:57 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Oil leak perhaps? Look for oil coming from your pass side valve cover gasket or rear intake manifold end seal.
Old Oct 18, 2010 | 08:00 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Man I feel your pain. I don't even want to know my cars history. All I know is some f*ckin hack had his hands on it that shouldn't have. Almost every under hood connector is disconnected.
If I were you I'd get a Haynes AND Chiltons manual and look at the wiring diagrams. Then just hope your wiring is still the same color. If you have AllData access thats even better, but few do....
Old Oct 18, 2010 | 11:46 PM
Car: 1989 Trans am
That's how mine is. It has a 350 in it and who ever did the swap didn't remove the wires that weren't needed after the swap, there connecters all over the place on mine too
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
