Starter problem
Starter problem
When I start my car I usually just get a click from the starter on the first try and the second try it starts. Now it clicks 3,4 or more times before it starts. I checked the connections and the solenoid and they all apperar clean and tight. The previous owner replaced the starter before I bought it , so I don't think it's that old. Any ideas? Shimming? bad battery cable? bad starter or solenoid.
Thanks,Tim
Thanks,Tim
Car: 88 gta (black/black wheels)
Engine: 350tpi
Transmission: 700r
Axle/Gears: 3.27 posi
Re: Starter problem
if it clicks, the solenoid is good, you have a cheap replacement starter thats going bad.
get a good one, that means not from advance, autozone, pepboys, orilleys.
best one is to get it from a starter and alternator shop thats reputable.
Car: '88 camaro iroc-z
Transmission: TH 700 R4
Axle/Gears: 2.77 Borg Warner Axel
Re: Starter problem
same problem in my 88 iroc 350 tpi!
sometimes it cranks first try, sometimes at the second, sometimes after 4 or 5.
when it doesn't crank i hear just a click from the engine bay: one when i turn the key and one when it comes back in the on position; as stated before, is this the solenoid doing its job?
also tried to hit the starter with a rod but nothing changed: it cranks randomly every time.
is it the starter in my case too?
is there anything else to check before getting a new one?
thanks
thanks
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Click Trick
Happy Racing!
How bout those too scared to drive without headlights in the daytime
and the ones that need headlights for a little rain
92camaroJoe
Aug 13, 2015 06:07 AM
db057
Aug 11, 2015 10:11 PM
