headlight problem
Old Oct 17, 2010 | 04:43 AM
teleman1957's Avatar
headlight problem
hi just bought a pontiac gta 5.7 tpi trans am and the problems are the headlights wont go down.and also the starter solenoid just clicks and it doesnt always crank over.are they any relays anywhere or do i need to check the starter motor first.it looks very tight to remove.cheers
Old Oct 17, 2010 | 05:21 AM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
Re: headlight problem
Headlights, IDK. Starter, check the connections at the starter and the battery first and check grounds for good connections. Second, have battery checked at Auto Zone for free. Last, have starter checked at Auto Zone for free.
Old Oct 17, 2010 | 10:36 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
For the headlights check the motors by direct jump from battery. The wiring diagram is in the book. It's most likely the control module (4inch square box on driver side firewall). top-downsolutions.com has a reman one for about $60.
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
