kinda dumb question... map and baro sensor
Old Oct 20, 2010 | 01:14 AM
imboredx0504's Avatar
i had a few people tell me my car has a barometric pressure sensor. the thing is. none of my diagrams show one and i cant find it under the hood. i know someone said its a blue connector. BUT i do have a MAP sensor and it has the vacum hose attached. i am wondering if this is a vacuum sensor like it says on the diagrams and there is no baro sensor needed for my car. i have an 83 z28 with a 5.0 4-bbl
ok. so i answered my own question. after finding out what wire coming from the ecm connector was for a baro sensor on a diagram, i checked the connector on my car and there was no wire that went to it. so no baro sensor.
Old Oct 20, 2010 | 06:25 AM
Jeffs82TA's Avatar
Re: kinda dumb question... map and baro sensor
the baro sensor looks just like a MAP sensor and I believe they were all mounted on the firewall right by the a/c evaporator core housing. I think the 84 5.0 h.o was the first to use it but maybe the 83 h.o had it as well. I don't think the 82-83 LG-4's had it.
Old Oct 20, 2010 | 09:39 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
From what I understand, there is not supposed to be anything connected to it because it needs to sense the relative pressure to the vehicle.
Old Oct 20, 2010 | 03:49 PM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
so whats the point if nothings connected to it?
Old Oct 20, 2010 | 04:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It measures atmospheric pressure, so it doesn't need any hoses connected to it.
Old Oct 20, 2010 | 04:28 PM
Engine: 357
oh, is there wiring to it though i assume?
Old Oct 20, 2010 | 04:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There is wiring.
When there's no dedicated BARO sensor, the ECM usually calibrates atmospheric pressure from the MAP before the engine starts, or at WOT when the manifold vacuum is zero.
Old Oct 20, 2010 | 09:37 PM
Ozz1967's Avatar
Car: 1984 Trans Am
That's what I was trying to explain but couldn't find the right words lol!
bbsr72
Apr 2, 2016 09:12 AM
86IROC112
Nov 27, 2015 09:54 AM
customblackbird
Oct 1, 2015 04:30 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
ULTM8Z
Sep 16, 2015 09:15 AM
