Voltage Drop as Engine Warms Up
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Have 105 amp CS130 alternator. Monitoring with TunerPro RT, when cold it shows 14.2 volts at the battery and 14.3 at the fuel pump. As car warms up to operating temp, the voltage drops to a range of 13.2-13.6 at the battery and 13.4-13.8 at the fuel pump. Have solid 0ga grounds (one from battery to engine and one from battery to frame), 8ga wire from Alt post to battery and 10ga sensing wire.
Two questions:
Two questions:
- What could cause the voltage drop from cold to hot (195* F)?
- What would cause more voltage at the fuel pump than at the battery?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Drop The Subject
It’s normal for the voltage to reduce itself from 14½ to 13½ after warmup to prevent shortening the life of the battery and alternator.
Happy Racing!
If You’re Passed By Your Own Tire On The Track, It’s Time For A Pit Stop
Happy Racing!
eightsixseven
Dec 16, 2024 01:50 PM
db057
Aug 11, 2015 10:11 PM
