side marker lights
Old Oct 26, 2010 | 11:46 PM
gump's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
Axle/Gears: 3:73
side marker lights
when I hit my brakes my side marker lights come on and if I dont have the headlights on and am in park they come on and the buzzer that tells me my lights are on rings what could thisa be? any insight would be great. thanks
Old Oct 28, 2010 | 11:59 PM
gump's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
Axle/Gears: 3:73
Re: side marker lights
nobody?
Old Oct 29, 2010 | 01:56 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally Posted by gump
When I hit my brakes, my side marker lights also come on. If I don't have the headlights on and am in park, they come on and the buzzer that tells me my lights are on rings. What could this be?
Did this problem just start from out of nowhere or, was it the result of some kind of wiring addition/change inside or, outside of the car ? (eg: adding a new radio or fog lamps). If the side markers light up, your front/rear park lamps should as well since they share a common circuit. Obviously, the rears won't be visible with the brake lamps lit.
If the problem occurred only with the brakes, I'd lean towards a bad ground in the rear light harness (stop lamps are chasing ground through the other lamps).
By 'and am in park', is that with the key just in the ignition or, the ignition in 'run', it's just sitting there with no key... ?
Personally, I'd probably start with pulling the 'door chime' unit out of curiosity and see what happens.
Old Oct 29, 2010 | 11:43 AM
gump's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
Axle/Gears: 3:73
I am not sure when it started as I just bought the car on sunday yes there is an aftermarket raido in it. and the buzzer only sounds in park when I step on the brake with or without the key in it
Old Nov 6, 2010 | 03:47 PM
gump's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
Axle/Gears: 3:73
I got it fixed it was the wrong bulb in the passenger side tail/brake lite
Old Nov 6, 2010 | 11:52 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Wow that is the oddest thing Ive ever heard when it comes to lights. Oh well good that it was an easy fix
Fronzizzle
Aug 17, 2015 02:52 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
