Electronic Oops.
Old Nov 2, 2010 | 09:45 AM
Chris89FBForm's Avatar
Car: 1989 Firebird Formula
Engine: 305 TBI (For now?!?!)
Transmission: Auto-Stock
Axle/Gears: stock
Electronic Oops.
Ok Boy-yos I'm in a bit of a pickle, I bought my 89 Godbird for 500 dollars and shes I've been slowly putting money in. Was from a friend who is in the military. Car ran, rolled, bumped, attracted ladies. Minus the few problems like code 42-43 popping giving me all kinds of hell, (need a new ign. module as it seems) I was quite impressed with the car. and for 500 for a car in as good of shape as it was anyone who complained should be shot ;D.
...back to topic; I was driving home from work and I turned a corner and then poof my radio is gone. I was like...um okay so after a few days of silent awkward driving, I decided to inspect, much to my dismay I never noticed that the dome lights did not work either, and then recently I noticed the horn did not work...nor do my power-locks OR mirrors T_T SOO I whipped out ye ole manual and found the fuse...and said..."Alas poor 15 amp, I knew thy well" gazed upon the unsullied fuse and then silently plugged it in and shortly after I BELIEVE I threw the nearest object in a fit of blood lust to this problem.
Now if you care not read the tale in short:
-radio, Pwr Locks, Pwr Mirror, Horn, Int lights, do not work AND fuse is intact.
I did a bit of investigation to the radio (aftermarket kenwood) and noticed that the wiring was kinda shitastic, so after I tinkered with the wires and got nowhere I found that there was a peculiar wire leading out to the hood. as I followed It suddenly stopped...now I BELIEVE that this was a negative wiresince there is electrical tape leading towards the battery and appears to be a missing segment of wire.
Any ideas?
Old Nov 2, 2010 | 10:53 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Electronic Oops.
Most likely not a ground. It was probably going to the + side of the battery. Those items all have separate grounds, but they only have 1 power supply connection. Check the terminals on the battery and see if one has some frayed wire ends sticking out of it. If you find that, you find where the wire goes.
Easiest way to test it is to disconnect the radio's harness and connect that wire you found to the - terminal on the battery. Then check the other items that aren't working. If they work, hook the radio back up and go. My guess is they won't so move the wire to the + terminal on the battery and test the other items again. That should do it, connect the radio back up and you're done.
Safest way to check it is to connect a DMM or continuity tester to that wire then probe both sides of the fuse terminals in the fuse block. If this test shows the wire is connected to the fuse block, it goes to the + side of the battery. If no continuity, then its either a ground or completely unrelated to your problems.
Old Nov 3, 2010 | 02:41 PM
Axle/Gears: stock
The problem isnt so much the radio is not working its the entire circuit that its on isn't working...domelights, horn, power mirror, locks AND the radio just stopped working one day
Old Nov 3, 2010 | 03:33 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Actually, those are spread across several different circuits. The horn and dome lights are on 1 circuit and the radio, power locks, and power mirrors are all on their own separate circuits. That's why I said the wire you found is most likely a +12V power wire that runs to the fuse block, not a ground.
Old Nov 6, 2010 | 11:45 PM
Axle/Gears: stock
I c I c, now the problem I find myself in is where that fuse box people speak of is
Old Nov 7, 2010 | 07:06 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Its under the dash on the driver's side. Just inside the door.
Old Nov 7, 2010 | 10:53 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I don't know about yours, but the ACC circuit in both my cars has the dome light, cigarette lighter, hatch release, door locks, under hood light and horn all on the same fuse. The most common culprit for blowing this fuse is the cigarette lighter, I've also had the under hood light blow the fuse.
Old Nov 7, 2010 | 12:48 PM
Axle/Gears: stock
ahh yeah this wire leads specifically to the engine bay, going thru the pass. side. But now I think I may know what the problem is. I was either checking the wrong fuse. and/or my battery was just too low of charge, It went out on me I had a generator sitting on it for a good 2 hours got it up to the mid-charge line, unplugged it and it went right into the warning threshold, now she wont even ATTEMPT to turn over, its like a bad nightmare lol
Old Nov 7, 2010 | 12:55 PM
Axle/Gears: stock
Yup same deal with mine, cept I have power mirrors added ^_^. But I think the problem originated from a bad battery not holding a charge and just killing itself with time
Old Nov 7, 2010 | 06:19 PM
Axle/Gears: stock
Well, its not the battery...so...now I have a car that wont even attempt to start. new battery, and none of the accessories work what a hole I'm in LOL
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
1992Z28!
Nov 19, 2015 07:33 AM
anesthes
Sep 30, 2015 07:48 AM
gta892000
Sep 16, 2015 12:37 AM
