Hazards problem
Old Oct 28, 2010 | 06:38 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Hazards problem
Hey guys, help me out
I Got my iroc and the turning signals have no problem at all and work fine. The hazards however have not worked since i got them, so today i found that the hazards fuse in the fusebox was not there. So I went and got a fuse, and when I turned on the ignition, or turned on the lights, it would make a buzz/ring. Whats going on? What do I need to do?
thanks
Old Oct 29, 2010 | 02:08 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Hazards problem
You didn't have brake lights either then.
Do the hazards at least flash as they are supposed to ?
The stop/haz fuse also powers the audible alarm (door chime, irritating sound). Seems like it may have went bad and someone yanked fuses until the noise stopped instead of yanking/replacing the chime itself.
Old Oct 29, 2010 | 06:25 AM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Re: Hazards problem
Where is the audio alarm located?
Old Oct 29, 2010 | 07:34 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Hazards problem
in your dash
Old Oct 29, 2010 | 08:04 AM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
Re: Hazards problem
lol, i read the title and thought them Duke boys were at it again...
Old Oct 29, 2010 | 10:04 AM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Re: Hazards problem
Where is it located under the dash? What does it look like?
Old Oct 29, 2010 | 04:42 PM
deadbird's Avatar
Engine: TPI 305/ v6
Re: Hazards problem
https://www.thirdgen.org/forums/post...15-post14.html
The arrow is point at the turn signal flasher. The black box directly under it is the audible alarm .
Old Oct 29, 2010 | 05:25 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Re: Hazards problem
Thanks deadbird, exactly what I was looking for.
What would make the alarm go bad? A short circuit somewhere or something?
Old Oct 29, 2010 | 06:19 PM
deadbird's Avatar
Engine: TPI 305/ v6
Re: Hazards problem
Could be age, a spike/short, the ign key contacts stuck together... They aren't really complex inside and came in most all 80's 90's GMs...
Old Oct 29, 2010 | 06:35 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Re: Hazards problem
Would the wires for the alarm just go under the dash? If i find faulty wiring for it, where would it be?
thanks for all your help deadbird, the pictures help alot too!
Old Oct 29, 2010 | 06:57 PM
deadbird's Avatar
Engine: TPI 305/ v6
Re: Hazards problem
In the tech section on the main page, https://www.thirdgen.org/technical-articles; there are links to 85-6 diagrams under 'electrical'.
Attached is for '91 but, all years should be the same/similar...
Old Oct 29, 2010 | 08:01 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Re: Hazards problem
Thanks alot deadbird, couldnt ask for anything more! (unless you want to come fix it for me haha)
Old Oct 30, 2010 | 11:00 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Re: Hazards problem
What would happen if I Just removed the alarm?
Old Oct 30, 2010 | 11:48 PM
deadbird's Avatar
Engine: TPI 305/ v6
Re: Hazards problem
Nothing, aside from not having that 'chime' telling you your lights are on or, your key is is the ignition.
I've yanked that box from every GM car I've had (which is why I could take that last picture of its internals).
Old Oct 31, 2010 | 08:57 AM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Re: Hazards problem
Ok, I think thats what I will do. Thanks alot deadbord!
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
