sticking starter solenoid? need help ASAP
Old Nov 1, 2010 | 11:26 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Ok so i went to start my car earlier and i turned the key, heard a loud click (like my battery is dead) and then all my power dissapeared... no voltage, no lights no nothing im leaning towards a sticking starter soleniod but im not sure...
THe PO used a marine solenoid for the starter which i have yet to replace, the battery was reading 12.63 volts so i know its good, good on CCA's, now when i tapped that solenoid the voltometer popped back up and it was all good, got it started but now its happening more often does this sound like a sticking solenoid???
Im probably gonna replace the solenoid itself because im broke right now, when i jumped the terminals it cranked every time so im thinking the plunger is outta wack, like i said being broke a 20$ solenoid is great compared to a $60+ starter im gonna toss when i do my t56 swap (tooth count)
any ideas? Info?
Old Nov 1, 2010 | 11:56 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: sticking starter solenoid? need help ASAP
If it is the old style big AC Delco starter you can reverse the contact studs and copper button in the solenoid cap to get another 100K out of it.
The contacts arc away over time not transferring power properly.Worth a look before spending $$$
Old Nov 2, 2010 | 12:23 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Ill give it a shot, the PO put in that marine solenoid like 3 years back now so I'm just gonna grab a new one, does the problemk described sound like a sticking soleniod? I know there's nothing else on the car that can draw that much power
Old Sep 19, 2012 | 06:37 AM
shittyelectric's Avatar
I have an 82 an I have a similar problem. I've never had a problem with the starter or it turning over but today I left my house drive to the store shut off go inside come out an starter jus spins the plunger wasn't engaging replaced solenoid and not plunger is workin but not spinning the starter???? Wat would cause this? Please help asap
mcbitchman
Sep 30, 2015 01:00 PM
Jlanz55
Sep 29, 2015 08:55 AM
mcbitchman
Sep 29, 2015 12:32 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ndndndnd
Sep 28, 2015 08:00 AM
