firebird headlights to Camaro wiring
Old Sep 17, 2012 | 03:48 PM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
I can't believe this hasn't came up yet but I searched and found nothing
I am putting a firebird front end on a Camaro (I don't care if think it a bad idea that's not what this post is about.) I need help wiring the headlight motors I want to use the stock Camaro light switch.
I have a donor firebird I have already swapped over the light and power wiring harness. The firebird harness had two extra wires so I also swapped those on the inside (Camaro) harness but I don't know where those two go or what is supposed to go through them
Again I am asking how to wire it up so Ican use the stock light switch
The firebird switch appears to control one more 'relay'? Than the Camaro switch is that inside the actual switch
Old Sep 17, 2012 | 10:05 PM
Andrew James's Avatar
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
Re: firebird headlights to Camaro wiring
Don't you already have a Bird?
Old Sep 17, 2012 | 10:38 PM
C.M.Jones's Avatar
Yes? I have 2 birds and 2 maros why?
Old Sep 17, 2012 | 11:48 PM
Transmission: WC T5
What prompted the clip swap?
Old Sep 18, 2012 | 10:14 AM
C.M.Jones's Avatar
Oh my goodness, Because I feel like doing it? Because I want 3, one of each. These questions aren't helping my technical issue
Old Sep 18, 2012 | 01:15 PM
Transmission: WC T5
No but they are satisfying my curiosity. It is also bumping this thread so that maybe, you will no longer be ignored as you have been in your search.
Old Sep 18, 2012 | 03:22 PM
C.M.Jones's Avatar
I've wanted a cross breed for a while and I picked up a Camaro body for practically free and then I got a really good deal on a firebird body (too bad it was a 5.7 GTA) now I'm pretty much putting them together
And I am going with a post apocalyptic theme on it as well with a couple surprises thrown in.
Old Sep 18, 2012 | 06:33 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You need to add a couple of pins to the dash side of the C100... Same issue I'm running into (other than finding a hood, passenger's fender, and decent bumper support for the front). I believe one pin is A4 (red wire, power to the module), and I'd have to look up the other couple of pins.
Probably easiest to just get a Bird harness and use that... While you're at it, upgrade the harness so that the headlights are run off of relays straight from either the positive battery terminal or the junction block... Enables HID lamps later.
:edit: Anyone who asks... I paid half as much for the 91-92 Bird parts (headlight parts, bumper covers and brackets, ground effects) as I did for the 88 with all of the parts inside of it. No sense in throwing them out (plus I just happen to like the Bird front and the narrower Camaro tail).
Old Sep 19, 2012 | 10:01 AM
C.M.Jones's Avatar
I had already added those pins to the c100 my problem was where they go from there, but I figured it out last night. The yellow one goes to the yellow one on the switch, the a white ones a little more involved as you have to wire a relay so that when the yellow one is powered the white one is grounded and visa versa. Now my lights go up and down with the Camaro light switch!
1992 Trans Am
May 10, 2023 07:19 PM
tnrednneck
Aug 13, 2015 08:57 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
