turn signals
Old Nov 11, 2010 | 02:52 PM
reaper20's Avatar
turn signals
I have a 1989 Camaro RS. The Left turn signal has recently stoped flashing. It just stays iluminated. The right one, and hazards, are still working fine though. Can any one help me out?
Old Nov 11, 2010 | 03:06 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Re: turn signals
Based on what you described, there is a bad bulb somewhere....if the hazards and right indicators are still working, that means the flasher unit in the fuse box area is still good, so theres a bad bulb somewhere, whether at the front or in the back, you'll have to find that out.
Old Nov 11, 2010 | 03:09 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: turn signals
Try removing the bulb and cleaning the socket. Pinch the connector too. Check the socket wiring for any sign of a crack that might expose any bare copper wiring possibly shorting the gound side of the circuit.
Old Nov 11, 2010 | 03:12 PM
Re: turn signals
if you get that far as to taking out the bulbs, then you can easily see the one thats burnt out lol.
Old Nov 11, 2010 | 06:50 PM
reaper20's Avatar
Re: turn signals
thanks, i will try it out asap and let you know if it worked.
Old Nov 21, 2010 | 10:59 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Re: turn signals
So... did you get it to work right?
Old Nov 23, 2010 | 09:01 AM
BLo602's Avatar
Car: 1989 Chevy Camaro RS
Engine: 350 TBI
Re: turn signals
So what could be the problem if both stay illuminated?
Old Nov 23, 2010 | 12:53 PM
V6canvas's Avatar
Engine: Stock LS1
Re: turn signals
Well, I just replaced 3 (of 6) taillight/brake light bulbs, 2 on the driver's side 1 on the pass side. All seems to be right with the world now. If it turned out to be a fluke, and the thing starts just staying on, I'll post up again.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
