Cleaning up engine bay wiring
Old Nov 16, 2010 | 12:40 AM
chevysurfer's Avatar
Car: 91 CAMARO RS
Engine: 305 TBI
Transmission: AUTOMATIC
I was wanting to know if anyone had any pict. or tips on rerouting/cleaning up the wiring on a TBI/CARBED engine.
I pulled all the looms, relocated the battery to the rear and moved all the relays to where the battery use to be. I am noticing while running the wires back to where they belong that its starting to look like a hot mess again. I want it to look better than before. Also I pulled all the smog stuff out (everything) and cruise control including tube and wires. Another thing is I want to move the coil off of the manifold any ideas? Any ideas of how to run the solenoid wires now that I just have a 0awg wire coming from the fire wall. Anything will help at this point.
Old Nov 17, 2010 | 04:09 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Cleaning up engine bay wiring
why do you have a 0G wire coming from the firewall?? Id suggest looking up the headlight wiring writeup on here, it will improve the headlight operation and it will also clean it up, id suggest getting new looming, that always helps cleaning things up, and i would spread your relays back out, theyre a clusterfk when theyre all together, painless sells a woven loom that you place around the wires and use zipties to put on makes it look amazing
Old Nov 17, 2010 | 02:46 PM
Car: 91 CAMARO RS
Engine: 305 TBI
The wire from the fire wall is the battery cable, running from the trunk. Im replacing the wire loom because mine are original and falling apart. I am going to check out that headlight wiring diagram, thats the only harness I didnt touch because its self contained. I have read some wiring upgrades that produce better lighting. Thanks for the info.
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
