87 T/A No power to the driver's side headlight motor/ driver's side turn signal
Old Nov 22, 2010 | 11:02 AM
platanoman31's Avatar
Car: 1987 Firebird Trans Am
Engine: 327
Transmission: A
Driver's side headlight wont flip up or down but turns on and driver's side turn signal doesn't turn on. Where the lights are turned on, left turn signal is illuminated in the car, but doesn't flash. i tested the headlight motors and the work fine, so I'm not getting any power the the side it seem. I HAVE NO IDEA WHERE TO START HELP PLEASE. I need to get it inspected very soon.
Old Nov 29, 2010 | 09:51 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Headed In The Right Direction
It sounds as if there is an open ground on the left side.
Check them all with an ohmmeter.
Then check the headlight door module.
The headlight module is a rectangular unit about 3" x 4" mounted on a bracket on the left side firewall.
It has two connectors.
The connections responsible for opening the left headlight door are terminals 2C & 2D.
Also there are TWO circuit breakers.
You can probe the two
orange wires going to the module to determine if the breakers are sending power to the module.
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
1992 Trans Am
May 10, 2023 07:19 PM
Caspar
Jun 19, 2016 11:19 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
