Where does this go?
Old Nov 27, 2010 | 01:48 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
Where does this go?
Hey guys, I was changing my oil pressure sending unit today and I noticed this connector, with purple and yellow wires coming out of it was not connected to anything. It comes off a wire bundle on the drivers side of my transmission. Any ideas where it goes, or if it's even needed? Haven't noticed any difference in my car so I'm curious if it's even needed.
Attached Thumbnails Where does this go?-chris-phone-142.jpg   Where does this go?-chris-phone-143.jpg   Where does this go?-chris-phone-144.jpg
Old Nov 27, 2010 | 01:59 PM
mightymaro94's Avatar
Re: Where does this go?
flux capacitor?...
Old Nov 27, 2010 | 02:11 PM
Engine: 350 S/B
I tried to stretch it out and see where it might lead to, but found nothing.
Old Nov 27, 2010 | 02:25 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Maybe an electric speedo connector.
Old Nov 27, 2010 | 03:29 PM
Engine: 350 S/B
Speedo works without it....I have no clue.
Old Nov 27, 2010 | 08:50 PM
could be for some option your car didnt come with.. idk .. maybe check a wiring schematic ?
Old Nov 27, 2010 | 09:05 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
pretty sure that would be a vss connector, maybe your car has a cable driven speedo/
Old Nov 27, 2010 | 09:16 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Does your car have (or had) cruise control?
Old Nov 28, 2010 | 12:36 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It certainly does look like it but, the camaro didn't have a vss/electric speedo until '90 when the dash changed.
A way out there guess would be that maybe your car got a harness intended for a 'bird since they had electric speedos starting in '86 (iirc). But, even then, there would have to be enough wire to reach the tail end of the transmission.
Old Nov 28, 2010 | 01:00 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
your reverse lights working?
Old Nov 28, 2010 | 01:07 PM
deadbird's Avatar
Engine: TPI 305/ v6
The wire colors for reverse lights are blue and green.
Old Nov 28, 2010 | 01:30 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Could it be the plug for the cold start switch on top of the engine ?
Old Nov 28, 2010 | 01:56 PM
deadbird's Avatar
Engine: TPI 305/ v6
Light purple and tan, cold start switch had an injector style connector as well.
Old Nov 28, 2010 | 02:25 PM
Engine: 350 S/B
Would that explain why my car doesn't like to start or stay running in the cold? If so where would I find the cold start switch, other then on top of the engine ? I do not have cruise control Scorpner.
Old Nov 28, 2010 | 04:16 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
I could see blue and green fading to purple and yellow. You don't have a lot of wires going to a cable driven 700, TCC and reverse lights is about it.
edit: just realised the autos don't have the reverse light switch on the trany, so I am going to go with torque converter lock up.
Old Nov 28, 2010 | 04:27 PM
deadbird's Avatar
Engine: TPI 305/ v6
I thought those had 3 wires on a 4 prong connector ? It's been quite some time since I had my auto camaro and donated the trans to my friends '72 truck.
Old Nov 28, 2010 | 04:49 PM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
How about your O2 sensor...Some models had the 2 wire...
Old Nov 29, 2010 | 02:38 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Ha, I'm in that boat. It has been some time since I had an Auto, I can't remember if the TCC was 2 wires or not. I do remember the last time I took the power train out I had a 2 prong wire pinched between the trans and the bellhousing . It was the TCC so was no longer of any use, different connector end than the one in these pics also IIRC.
Perhaps deadbird is correct and you have a firebird wiring harness, it does look like a VSS connector, but like he said it would need to reach the tailshaft.
Old Nov 29, 2010 | 08:21 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
This is correct I was thinking of the coolant temp switch style plug . I would have to jack my car up to look at the VSS plug and wire colors to compare .
Old Nov 29, 2010 | 10:33 PM
Pocket's Avatar
Car: 91 Trans Am
Its VSS and camaros didnt have this until 90 when the electronic speedo were introduced. Its also the 89 and older style connector
Is it possible your engine/harness are not original to your car?
Old Nov 30, 2010 | 09:04 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Pocket is correct. Its the VSS. And I know this because my wiring harness is laying on my living room floor right now
Old Dec 1, 2010 | 06:56 PM
Engine: 350 S/B
I'm not for sure if the engine/harness have ever been replaced. I don't have a lot of past history as far as previous owners as to whats been done. i've only had the car for almost three years now.
Old Dec 1, 2010 | 07:06 PM
Pocket's Avatar
Car: 91 Trans Am
If your speedo works right now, dont worry about it
Old Dec 2, 2010 | 06:22 PM
Engine: 350 S/B
Speedo works so I guess it's all good.
