Alternator whining... louder with acceleration
Old Nov 30, 2010 | 03:04 PM
86IROC57L98's Avatar
Car: 1986 IROC-Z28
Engine: 5.7L L98
Transmission: 700R4 OD
Axle/Gears: B&W 3.27 Posi- :D
Ok, I got another alternator to replace the one in my car that had gone bad after about 4 months??? dont know why. But this new (reman) one is whining like a supercharger and has the same rythum (louder under acceleration). Not screeching the belts or anything. So it took it off because i wanted to test it and it passes 3 tries. And i watch my voltmeter and its kinda twitching between ill say 13.7-12.7 volts - ish. But this morning its been ok stayin above 13v. Ive heard the whining is bad and is a sign if it about to go out? is this true. I also think my gauge may be a little faulty or needs to be cleaned too?? Just not sure what the whining means
Old Dec 3, 2010 | 08:50 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Alternator whining... louder with acceleration
if the whine stops when the voltage regulator plug is
off,that indicates there is a shorted diode in the alty
Alternator will still work but it will be weak and will
get real hot,even with a light electrical load.
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
