Question about kill switch
Old Dec 2, 2010 | 09:11 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Ok I would like eventually put a kill switch into my car I have read alot about splicing into the neutral safety switch, fuel pump wire etc. My question is I plan on going from my stock ecm set up to a built carbed engine, after doing this I will be eliminating the ecm so how and where should I install the kill switch. If anyone has a set up on a carbed engine please tell me how you did it and post pics advice etc.
Old Dec 2, 2010 | 11:18 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Question about kill switch
Only takes out the starter ; easily bypassed
I have read alot about splicing into the fuel pump wire etc.
Also easily bypassed if you have enough time.
Best way with a carb setup is to ground the coil neg wire through a switch.
If you do a tidy job and hide the wiring correctly no amount of jumpering or bypassing will get the dist to make a spark ; next to impossible to find
All you do is cut into the white coil wire from the coil neg somewhere ( goes to tacho ) and run that to ground through a switch.
If the coil is hot wired direct from batt to bypass Ign switch as is commonly done by thieves;
power goes direct to ground and not into dist; No spark
Old Dec 4, 2010 | 03:17 PM
Engine: 383 stroker
Thanks for the info
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
