Another buzzer thread(Yes i did use search)
Old Dec 10, 2010 | 07:45 PM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
OK, found plenty of stuff that lists where the headlight buzzer is.
Already know where it is, and already removed it.
After doing to trip odometer fix (https://www.thirdgen.org/forums/faq-...-fix-pics.html), which involves pulling the cluster, and for me, dropping the steering column to put it back.
After putting everything back together, the buzzer comes on like normal when you start the car, but it doesn't turn off.
Here is my question.
I opened the buzzer itself up and seen that there are ALOT of components for a buzzer(which may be normal being it was designed in the 80's). Is there any negative effects on the electronics or other areas in the car if it is removed and never put back? I'm pretty sure the answer is no, but would still like to know if anyone ran into any problems doing so.
Thanks in advance
Old Dec 11, 2010 | 04:57 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Another buzzer thread(Yes i did use search)
Door chime, headlight warning chime, radio chime all in-op. If you arent careless in leaving your electronics on when the car is off, youll have no problems. I prefer to have the buzzer removed because it grates on my nerves
Old Dec 11, 2010 | 08:58 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
+1
Old Dec 11, 2010 | 10:48 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
you can leave it in line and just pull the meta disk in it so that it cant chime makes it easier on you, 4 screws IIRC and a simple fix
Old Dec 11, 2010 | 11:01 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i pulled my buzzer because it got tired of it buzzin with the parking lights on sittin around hanging out
mines been out for 9 years now, dont miss it one bit
if your ever on I-10 in harrison county mississippi look for the seat belt chime out of my box truck, i got tired of it chiming all the time so i unhooked it and tossed it out a 75mph
Old Dec 12, 2010 | 01:55 PM
willexoIX's Avatar
Thanks for the replies, I wasn't really worried about it, but as they say "Better safe than sorry."
The metal disc can be removed by popping the clips on the little black box, the 4 screws your referring to are for the panel removal to get to the convenience center i think.
Again, thanks for the replies; This is the reason I come back here time and time again, well plus the fact that I have a 3rd Gen, lol.
Cheers
Linson
Sep 21, 2015 01:08 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
383cam
Sep 9, 2015 06:01 AM
Slush92RS
Sep 2, 2015 08:56 PM
SlowAZ28
Sep 2, 2015 05:19 AM
