tach fix
Old Dec 11, 2010 | 08:18 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
tach fix
This is for the 90 tpi iroc, it might work for others I dont know. I swapped from tpi to carb. I removed 95% of the wiring that went to the computer. I removed the computer also. Then my tach or oil pressure gauge would not work effectively, the tach would not work at all. All of the info I could find pointed to the white wire from the distributor, but it was hooked up, with voltage. Finally I got the repair manual out and found tach repair info. The way the 90 camaro is wired the ground for the instrument panel goes thru the computer. Its the blk/wht wire in the 6 wire plug for the computer. I jumped it out to the car body and the tach started working and all the other instruments worked too. So the tach repair got my complete instrument panel working.
Old Dec 11, 2010 | 09:05 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: tach fix
blk/white is just chassis gnd, tach still gets spark pulse from white tach wire off coil.
Old Dec 11, 2010 | 09:28 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Re: tach fix
Thats true, but the tach wont work without it. The one I am talking about is in the connector that was plugged into the computer under the dash passenger side.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
86maro_252
Oct 10, 2015 06:52 PM
BWilcox
Sep 20, 2015 12:19 PM
TrevinE
Sep 14, 2015 03:20 PM
