Wiring an alternator
Old Dec 13, 2010 | 07:26 PM
mike23109's Avatar
I just finished rebuilding the motor of a 1992 Z 28. The engine had already been out of it when I got it. I noticed on the alternator that there is a plug for wiring harness. This is plugged in. There is also a post and nut on the back of the alternator. I can't find any loose wires nearby that go to this. I checked a wiring diagram and it appears something goes here. Am I reading the diagram incorrectly or am I missing a connection? If am missing something where might it be.
Old Dec 13, 2010 | 07:42 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Wiring an alternator
You can just run it to the battery. (Using the proper wire gage of course)
Old Dec 13, 2010 | 08:12 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Yes thats where it goes, battery. 10 gauge will work.
Last edited by Dustytrix; Dec 13, 2010 at 08:14 PM. Reason: put wrong size first time
Old Dec 13, 2010 | 09:46 PM
mike23109's Avatar
Thanks guys!
eightsixseven
Dec 16, 2024 01:50 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
