which ecm to use??
Old Dec 15, 2010 | 10:20 AM
dirtywhiteboy's Avatar
which ecm to use??
i'm looking at an 88 iroc with a 305 TPI and T5.
he has a complete 350 TPI engine to go with it but i don't know if he has the ECM or not.
i know the 350 had an auto behind it so i don't know if i should use the ECM for the 305/T5 or use/find an ECM from a 350 TPI.
either way, should i have to re-program it or should i be able to use stock parts?
Old Dec 15, 2010 | 12:18 PM
Brads RS's Avatar
Re: which ecm to use??
You should only need to change the eprom. Check Ebay for a 350 prom, your prob not going to find one for a 350/MT as i dont think that combo was ever made in 88 but i could be wrong. Just get one for an automatic it will work fine. Or have your prom reprogrammed for a 350. check out www.larryselectricsite.com if you call they can normally reprogram your stock chip.
Old Dec 15, 2010 | 06:29 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Brads RS
You should only need to change the eprom. Just get one for an automatic.
Make sure you have a 350 TPI knock sensor to make the eprom ( 305 is different )
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
