LED footwell lights
Old Jan 7, 2011 | 05:49 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
LED footwell lights
Can you change the foot well lights to LED because put alot of wiring into my dash and those lights get freeken hot are there any direct replacements known of or do you need to change the socket?
Old Jan 10, 2011 | 12:20 PM
NINĹ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Thunderbolt & Lightfoot
What type of bulbs are in the sockets now?
Also, an option would be is to use a LED strip for more even lighting.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Jan 10, 2011 | 02:22 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: LED footwell lights
sockets should be 194 bulbs, very common size. you can change to a drop in led replacement or do as NINĹ recommended and splice in some led strips instead. just make sure you tuck away the strips for a cleaner look (nobody wants to see your bulbs, just what they can do!)
Old Jan 10, 2011 | 06:38 PM
Red 87 GTA's Avatar
thanks ill see what i can find
Old Jan 10, 2011 | 07:18 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
How much wiring do you have under your dash that has you worried about those bulbs melting it? Chef Boyardee been cooking up some spaghetti under there?
They made LED replacement bulbs for every bulb on cars now, actually had a drag car in my shop awhile back for a complete wire job and the guy wanted all LED's, he said it would make the car faster because the alternator would work less. I told him to far out the window, you'll get the same result. True story.
Old Jan 10, 2011 | 07:51 PM
Red 87 GTA's Avatar
ive got a whole clifford alarm in there with remoter start power relays for trunk defrost ect. so its one of those dash panels that needs to get pused up to close so i dont want to cook my wires away
Old Jan 10, 2011 | 08:01 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Wait wait wait... there are foot well lights? Did they come on all the third gen camaros and firebirds? I was planning on putting in some LED lights but I think I'm going to do this instead because it would have a cool effect and match my car.
http://www.autozone.com/autozone/acc...ier=341406_0_0_
Old Jan 10, 2011 | 08:04 PM
Red 87 GTA's Avatar
you should have litle lights in the under dash pannels look mabey they burt out and you didnt notice
Old Jan 10, 2011 | 08:16 PM
Is that the area between the carpet and the bottom of the dash.
Old Jan 10, 2011 | 08:43 PM
Red 87 GTA's Avatar
the botem part of the dash where the fuse cover isthere should be a little dome looking thing there is light behind
Old Jan 10, 2011 | 08:48 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
not all years had them...they were a lot more common in the firebirds
Old Jan 10, 2011 | 09:07 PM
Red 87 GTA's Avatar
i do think pontiac spent more on interior than chevy did
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
