one headlight not other?
Old Jan 10, 2011 | 07:44 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
one of my headlights come up but the other does not but if i crank it up when i hit the switch to shut them the both go the hell down corect me if im wrong but isnt there just a split from one light to the other so how the hell could this happen i cant have a bad conection if it goes down im baffled what could be the problem
Old Jan 10, 2011 | 08:05 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: one headlight not other?
The headlight motor bushing is probably bad. I think thirdgen ranch used to sell bushings for 10 bucks.
Old Jan 10, 2011 | 08:07 PM
Red 87 GTA's Avatar
i recently rebuilt both motors and replaced everything with aluminum parts
Old Jan 10, 2011 | 08:09 PM
gp90gta's Avatar
Car: 1990 GTA
Had the same problem last year, it was my bushings in the motors, changed them and now there perfect.
Old Jan 10, 2011 | 08:11 PM
Red 87 GTA's Avatar
but i dont get voltage to put the motor up but i get it to put it down
Old Jan 10, 2011 | 08:13 PM
bigj350's Avatar
You may need to replace the motor then. I did a search and found this thread about metal VS plastic bushings. Hope it helps
https://www.thirdgen.org/forums/afte...headlight.html
Old Jan 10, 2011 | 08:21 PM
Stephen's Avatar
Car: 87 GTA
Wrong, Wrong, Wrong.....
The headlight door control module has separate circuits for each headlight, for this exact reason. If the control module went out, then both headlights wouldn't work. By having dual circuits, each headlight is separate & not likely that both circuits could fail at the same time. This way, you at least have 1 headlight & don't lose both.
Old Jan 10, 2011 | 08:27 PM
bigj350's Avatar
I didn't know that. Thanks I learned something new today!
Old Jan 10, 2011 | 08:38 PM
Red 87 GTA's Avatar
well were is the controlmodual for the pas side headlamp so i can fix the dam thing
Old Jan 10, 2011 | 08:43 PM
Stephen's Avatar
Car: 87 GTA
It is just 1 Module, with dual circuits inside it.
On the firewall, drivers side, just right of center & left of the brake booster. It has 1 plugs on it & slides to the right to come out of its bracket.
Old Jan 10, 2011 | 08:54 PM
bigj350's Avatar
So thats what thing does! Im not being a smart***, as sad it sounds I did not know that. Even worse, Ive had at least 8 Firebirds in the last 14 years. I feel like an idiot.
Old Jan 10, 2011 | 09:00 PM
Red 87 GTA's Avatar
so there are no splices in the front of the car to be problematic right? where would i find a new control unit too?
Old Jan 10, 2011 | 09:42 PM
Stephen's Avatar
Car: 87 GTA
If the headlights come up with the ****, that indicates the motors are good (and you rebuilt them anyways), so that points to the motor simply not getting power.
I bet you could jumper power to the motor. If it goes up, that points even more towards the Module being bad. Maybe the 2 headlight plugs could be switched on the Module & see if the one not going up switches?
Old Jan 12, 2011 | 12:48 PM
Red 87 GTA's Avatar
ok i fixed the modual took it apart and murdered it with conact cleaner and it started to work again thanks.
Old Jan 12, 2011 | 12:50 PM
Red 87 GTA's Avatar
i know how you feel ive had that thing out when doing master cylender service and a few other times who would of thought. The dam thing almost looks like a small ECU type of thing
Old Jan 12, 2011 | 01:06 PM
Stephen's Avatar
Car: 87 GTA
Glad it worked out for you. I had one doing the same thing & cleaning it didn't help, so I replaced it with a spare I had laying around. At least I didn't hafta buy one.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
