dash light cluster
Old Jan 20, 2011 | 06:51 AM
SlyFox1984's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7L V8
dash light cluster
My gta has recently, in the past two days, started having lights turn on on my dash. The seatbelt light will come on while I'm driving and wearing my seat belt mind you. Not sure if wires are just messed up or if it is something serious. Also cannot get my stereo to hold memory got it wired up to work with everything right except for them memory. Does anyone have advice?
Old Jan 20, 2011 | 03:20 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: dash light cluster
Did you use the factory wires for your radio? I would check grounds. Also the key buzzer is part of the selt belt warning light circuit (though my key buzzer works, I have never heard a noise for my seat belts while driving). The key buzzer is on the convience center located under the dash about where your right knee would be when driving. Its a socket with the key buzzer and hazard (not turn signal) relay plugged into it.
Old Jan 20, 2011 | 03:46 PM
SlyFox1984's Avatar
Engine: 5.7L V8
I did use the factory wires had a friend help me with the wires as well. Tied hot wire and what was thought to be the acc wire together to make it work and turn on and off and hold memory but mem didn't work
Old Jan 20, 2011 | 04:11 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Ok just addressing the radio, the power for the radio should be a yellow wire. That would give 12volts with the key on or in ACC postision.
The hot at all times for memory is orange. Normally orange wires are hot wires.
Old Jan 20, 2011 | 04:14 PM
SlyFox1984's Avatar
Engine: 5.7L V8
Alright I will check to see if I can find an orange wire if its not already connected thanks.
Old Jan 20, 2011 | 04:25 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Ok I'll wait.................. will you hurry up though, I gotta go pee! ..................
Old Jan 20, 2011 | 04:29 PM
SlyFox1984's Avatar
Engine: 5.7L V8
Your fine I'm prolly gonna look at it tomo. Gotta get to work.
Casey Meyers
Mar 2, 2016 10:46 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
