Wiring for the heater/AC control
Old Jan 22, 2011 | 06:01 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
They're right in the center of the firewall, Can I just hack these off? I'm not using heat, or A/C anymore, and they're about 1" from the header so they may burn up...
Old Jan 22, 2011 | 12:09 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Wiring for the heater/AC control
Given how far north you are, I wouldn't get rid of the heat permanently by 'hacking' the wires. 1 inch is plenty of space - if worried, wrap the end close to the header with some heat material like used for the starter, or else use one of those plug wire protector sleeves.
Old Jan 22, 2011 | 07:32 PM
Pocket's Avatar
Car: 91 Trans Am
1" is plenty of clearance
If you're talking about the HVAC mini-harness behind the pass cyl head, just remove it. Take out the HVAC headunit and unplug it. Pull the grommet through and unplug it from the engine harness
eightsixseven
Dec 16, 2024 01:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
