Wiper motor mayhem!
Old Jan 22, 2011 | 11:20 AM
signaturecustom's Avatar
Wiper motor mayhem!
Hey guys,
Has anyone had their wipers go nuts? I got an 84 TA and when you turn the wiper stalk on all the wipers do is go on the constant LO setting. No HI, no intermittent and more worryingly, no OFF!! The only way to stop them is to turn off the ignition with the switch off. Once the ignition is turned back on (with the switch still off) the wipers wipe once and return to the park position! I'm lost, been looking at it all day
HHHEEELLLPPPP!!
Old Jan 24, 2011 | 09:16 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Rain Pain
Disconnect the wiper motor module connectors C1 & C2.
Have the wiper switch in the OFF position.
Have the key in the ACC position.
Measure voltage on C2a.
Measure voltage on C1b.
They need to be zero.
If you have voltage there the switch is bad, or a wire is shorted to a voltage source.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
Old Jan 24, 2011 | 09:37 AM
Re: Rain Pain
You mean disconnect the motor itself or a motor module? Where is the control module and what does it look like?
Many thanks
Rich
Old Jan 24, 2011 | 11:14 AM
NINÅ's Avatar
Transmission: 765R4
Rain Pain
The module is on the left side of the firewall in the wiper motor assembly.
The connectors you will be disconnecting is the 2 pin connector going to the motor, and the 1 pin connector going to ground.
Insert a voltmeter in line with the 2 pin connector
purple wire and ground for measurement #1.
Insert a voltmeter in line with the 1 pin connector
gray wire and ground for measurement #2.
Happy Racing!
Old Jan 24, 2011 | 09:02 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: Wiper motor mayhem!
Nina. You seem to be pretty smart on this electrical testing stuff. Could you recomend a good site on how to actually use these meters. I have two, but no clue on how to use them. Thank you
Old Jan 25, 2011 | 01:44 PM
NINÅ's Avatar
Transmission: 765R4
Meter Maid
What are the make and model numbers of the meters?
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Frozer!!!
Jan 19, 2024 04:55 PM
siberian3rdgen
Interior Parts Wanted
Aug 31, 2015 09:37 PM
Randomtask2
Aug 26, 2015 03:34 PM
eddie jr
Aug 25, 2015 06:52 PM
slade5612
Aug 11, 2015 07:19 PM
