altnator drain
Old Jan 24, 2011 | 10:38 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
altnator drain
OK,I figure my altnator is draining my battery.When the car is not running the bat. will go dead in a short time. If I disconect the altnator and leave the bat.cables hooked up everything is normal.NOW a guy gave me an alt. in part of a trade deal about a month ago and just got a chance to try it.The bolt patterns line up but the top t-40 hole dosn't have threads.looks like they were drilled out.And the stud that comes out the back is a treaded bolt with a nut on it,instead of a flat stud with a treaded hole to recieve a small bolt.I could just put a bolt with nut and washers in the top hole.and the stud dont look like it should have a problem with the tapet covers.One issue there,my insulation cap suffered mouse damage from previous owner.how hard are they to get?Think this alt should work?Other than that it looks the same.Shouldn't fry out my system should it?
Old Jan 25, 2011 | 01:31 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Insulation Contemplation
You can get those at ripCAMARine.com
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Jan 25, 2011 | 09:18 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: Insulation Contemplation
tried your sight.It showed german or somthing and I couldn't get things to work for me.Thanks for trying
SRKLEGIN
Oct 29, 2015 06:38 PM
85cmroz28
Oct 4, 2015 09:44 PM
raymondandretti
Sep 27, 2015 06:43 PM
ericjon262
Sep 11, 2015 06:07 PM
89 formula TPI
Sep 7, 2015 11:06 AM
