help won't turn off
Old Feb 6, 2011 | 06:15 PM
youhadnochance's Avatar
Car: 1989 camaro
Engine: 383
Transmission: t5
Axle/Gears: 10 bolt 308
help won't turn off
Ok I have an 89 camaro.My problem is when I plug in the oil pressure sensor my car won't turn off.I can turn the key off and pull them out and it keeps running.I am running a carb so there isnt really any electronics hooked up.????
Old Feb 6, 2011 | 06:46 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: help won't turn off
Power to coil keeps engine running so somewhere you have a wiring problem that is putting 12V to the coil bypassing the IGN switch
Check wiring
Old Feb 7, 2011 | 08:41 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Car Wants To Go Out On The Town — Without The Driver
Yes he does, and probably involves the oil pressure sending unit line.
Therefore, using an ohmmeter, locate the short or erroneous connection by connecting one test lead from the
gray wire at the oil pressure sending unit, and the other lead to the coil primary key side.
You should see low resistance there.
However you want high resistance.
Therefore backtrace the circuit between the ohmmeter probes to find the short or erroneous connection.
(When using an ohmmeter, make sure there is no voltage present at the moment in the circuit under test.)
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
Old Feb 7, 2011 | 11:37 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Your car should have originally had a fuse, pass side, between battery and fender, tucked inside a weatherpack. See if it's still there, and remove it. Now see if the car keeps running.
Not sure how you have the fuel pump wired - but that fuse is the fuel pump circuit that runs through the oil pressure sending unit. If you are still using the in-tank fuel pump, removing that fuse may keep your fuel pump from running - but at least you know it's that circuit that's backfeeding the power to your coil wire, and then you can go back and rewire the fuel pump.
Prodigious
Nov 7, 2020 09:23 AM
Derick15
Sep 17, 2016 05:28 PM
WIzmo
Aug 30, 2015 02:30 PM
ZsTransAm
Aug 11, 2015 07:30 PM
BrianI
Aug 9, 2015 11:52 AM
