Can someone tell me what this box is? Pics included
Old Feb 12, 2011 | 08:40 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Appears to be some type of alarm maybe, it's connected in center console, I'm in the process of cleaning my wiring just wanted to be sure before i yank it. I also have some loose connections no clue what they are i'l include pics.
Box
wires
Old Feb 12, 2011 | 09:52 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Can someone tell me what this box is? Pics included
The square part in the center console that is still mounted to the hump in your last 2 pics is for the airbag stuff. That's why it has an arrow on the top pointing forward - it needs to point forward in order to properly work the airbag. Exactly what it's called I don't know - bnut it is airbag stuff and is factory.
The gadget in your top pic, not sure. Check wiring diags and see here:
http://www.austinthirdgen.org/index.php?pid=19
Just about every diagram for a 1992 is there is you scroll down - will all be the same for your 1991.
Old Feb 12, 2011 | 10:18 PM
godreject's Avatar
yea the air system stuff i recognize, plus that wiring is in tact, its the window switches and other wires that are splice and go tie into the box
Old Feb 13, 2011 | 01:48 AM
Twin_Turbo's Avatar
Looks like an alarm to me
Old Feb 13, 2011 | 01:08 PM
Car: 1992 RS
Engine: Carbed 350
Have you unplugged it to see what happens? Do all the windows, trunk release still work with it unplugged?
Any other markings anywhere? Can you open it up - maybe there's a brand name stamped inside that you can google?
Is there any funky wiring connected to the horn, or the horn relay? Was there an additional horn under the hood (like an alarm)?
I'd unplug it and see what happens. If nothing changes, save it (just in case someday), and forget about it.
Old Feb 13, 2011 | 01:15 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
http://www.buy.com/prod/directed-529.../90148271.html
Old Feb 13, 2011 | 01:26 PM
Car: 1992 RS
Engine: Carbed 350
Power Window Module - wow! Now we know!
Deadbird - I can see since it was mentioned about the widow wire splices that you'd think window module - but how in the heck did you manage to actually find THAT ONE? There must be 100 different such gadgets! Good find - I'm impressed!
Old Feb 13, 2011 | 01:53 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
that's a great help, but it's amazing what google will tell you..
http://www.google.com/images?rlz=1T4...w=1131&bih=644
Old Feb 13, 2011 | 02:12 PM
Car: 1992 RS
Engine: Carbed 350
If I had googled "529T" - I'd gotten 15 million porno page hits!
Old Feb 13, 2011 | 03:45 PM
godreject's Avatar
ok Thanks for the help, window module i figured such.
Old Apr 18, 2012 | 08:17 PM
Camman9167's Avatar
Car: 1991 Camaro RS
Engine: 305 Small Block
Axle/Gears: Factory
On the subject of the stupid airbag box thing, can i just yank that out of mine, im changing the steering wheel and just want to rid the car of all the bullshit airbag wires
Terrell351
Jun 13, 2021 01:13 PM
zerogsx
Feb 6, 2016 11:29 AM
Thomas
Oct 3, 2015 05:34 PM
Dialed_In
Aug 20, 2015 01:45 PM
Street Lethal
Aug 13, 2015 08:28 PM
