rear defroster only slightly works
Old Feb 16, 2011 | 06:13 AM
the rookie24's Avatar
Car: 1992 rs stock for now
Transmission: auto
my rear defroster started acting wierd today i started up my car turned it on and when i came back to get in the window was still frozen only a small sliver was melted on the top drivers side on two of the heat elment lines that go across the window ibut i was like this ------() snow that circle is that box thing at the top of the glass what could cause this a loose connection?
Old Feb 16, 2011 | 04:17 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: rear defroster only slightly works
There's a wire on each side that connects to the hatch struts - either of them popped of? I think they are the grounds for the circuit.
Old Feb 18, 2011 | 06:12 AM
Transmission: auto
i check i have four connection on the window two at the top of th struts and two at the bottom i wd 40 all them and yesterday i put it on when the window was fog and i saw it clear up but then this moring only two lines on the top left were clear the rest was still foggy mabye i jus need to do a hardcore cleaning to all the connections
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AkDrifted
Aug 17, 2015 07:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
