Which knock sensor???
Old Feb 18, 2011 | 08:31 PM
campbellerman's Avatar
Car: 1990 Trans Am
Engine: 305 TPI L98 cam
Axle/Gears: 3.42 eaton
Hey guys i did a search but i couldnt find anything that was pertaining to what i was looking for. ok... i have a 1990 trans am with 305 tpi that has swirl port heads on it and about ten years ago the knock sensor was replaced by the owner well, the engine died and he bought a reman engine from advance and he used all the original tpi electronics on the new engine. heres my dilemma...i need to buy a knock sensor cause mine is bad what is the difference between the two sensors? and which one do i need? here are the part numbers from autozone and oreilly for the lb9 and l03... that was long but thanks for reading and any help that you can give me
the Zone
89 trans am lb9 su121
90 trans am lb9 su150
89 camaro rs l03 su121
90 camaro rs lo3 su121
oreilly's
89 trans am lb9 2ks26
90 trans am lb9 2ks27
89 camaro rs l03 2ks26
90 camaro rs l03 2ks26
Old Feb 18, 2011 | 09:43 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Which knock sensor???
Your engine is NOT an LO3 - so you can eliminate those - LO3 is a TBI motor, not TPI.
I see AZ has a different part number for 1989 and 1990 - if your car's ECM is a 1990, then I'd get the 1990 part (which is the SU121).
Old Feb 19, 2011 | 05:31 PM
Car: 1990 Trans Am
ok cool so i need the one for a 90. thanks i bet your car looks sharp teal looks great on camaros
Old Feb 19, 2011 | 05:45 PM
Car: 1992 RS
Engine: Carbed 350
Thanks - I'm rather fond of it.
Old Feb 19, 2011 | 05:57 PM
Twin_Turbo's Avatar
Camaro 1992-1990 3.1L (T) 189 10456019, 10456208, 10497163 29015
Camaro 1999-1996 3.8L (K) 231 10456215 29026
Camaro 1980 4.9L (T) 301 1997463 29017
Camaro 1982 5.0L (7) 305 1997463 29017
Camaro 1992-1990 5.0L (E) 305 1997562, 10456017, 10456287 29014
Camaro 1989-1988 5.0L (E,F) 305 1997562, 10456017, 10456287 29014
Camaro 1992-1991 5.0L (F) 305 10456126 29020
Camaro 1990 5.0L (F) 305 10456019 29015
Camaro 1986-1983 5.0L (F) 305 1997562, 10456017, 10456287 29014
Camaro 1987 5.0L (F,H) 305 1997562, 10456017, 10456287 29014
Camaro 1992-1990 5.7L (8) 350 10456031, 10456549 29019
Camaro 1989-1987 5.7L (8) 350 1997699, 10456018, 10456288 29016
Camaro w/Locating Tab, 1st Design 1998-1998 5.7L (G) 350 10456222 29029
Camaro 1995-1993 5.7L (P) 350 10456126 29020
Camaro 1997-1996 5.7L (P) 350 1997562, 10456017, 10456287 29014
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
