Difference in Knock Sensor plug and fan temperature plug
Old Feb 18, 2011 | 08:58 PM
iosigma's Avatar
Car: 2017 Jeep Cherokee
Transmission: 6 Speed, 5 Speed T-5
Can anyone tell me the difference between the fan switch plug and knock sensor plugs on the passenger side on a 305 TBI vine e. Both are the same size. one is black and the other one is white. I dont know which color belongs with which. Thanks for your help!
Old Feb 18, 2011 | 09:39 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Difference in Knock Sensor plug and fan temperature plug
Neither should be black.
Knock has dark blue. Fan switch has green/white.
Connect one of them to a ground with the key on, if the fan runs, then that's the fan switch wire.
http://www.austinthirdgen.org/mkport...ine_wiring.gif
Old Feb 19, 2011 | 02:25 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I think iosigma was referring to the color of the connecting plugs. and Newbie is talking about the color of the wires they are attached to, but everybody's probably figured that out by now. Hey, I'm catching up!
eightsixseven
Dec 16, 2024 01:50 PM
db057
Aug 22, 2015 08:17 PM
timonator
Aug 11, 2015 09:56 PM
gwade12
Aug 8, 2015 08:17 AM
