Turn Signal Help Please!
Car: 1984 T top Trans Am
Engine: HO 305 V8
Hi all, I have a very weird problem on my 84 t/a that's been going on for some time now. It used to work fine but over time well this has happened:
When I use the turn signal stalk, and turn left or right - the outer lights blink for turning no problem - (front parking, front side markers, and rear tail light turning sections.) Now the inside arrow indicators - you can hear it on and off but it doesn't blink mainly when turning left, then sometimes it does. Also, right side same way, but when you pull down on the hazard light cylinder for the emergency lights - they come on and freeze but the outer lights all function fine. This is driving me nuts! What is going on here and what is the fix for it?
All help is Greatly appreciated!!
Thanks in advance
Jeff
Thanks in advance
Jeff
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Turn Signal Help Please!
4-way flashers have a different flasher unit that the turn signals, that might be an issue.
That's weird that the outside lights work and flash - usually when the indicators burn solid, that means a bulb on the outside is blown. So I'm stumped - maybe it's a dash/cluster issue.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Duke Of Hazard
When you say “when you pull down on the hazard light cylinder” do you mean when you turn on the Hazards, OR do you mean when you put some pressure on the button cylinder?
When you say “you can hear it on and off but it doesn't blink” do you mean the Indicators do not come on?
Happy Racing!
Make Noise, Turn Left, Repeat
Happy Racing!
Engine: HO 305 V8
Re: Duke Of Hazard
Transmission: 765R4
Duke Of Hazard
Grab a small light bulb such as a side marker.
Throw it in a spare socket or solder leads to it.
Connect one of the leads to the light blue wire at the connector located behind the dash on the right side of the steering column.
It’s a flattish connector with up to 11 wires in it.
(Don’t disconnect the light blue wire just tap in to it.)
Connect the other lead to any ground.
Position the bulb in an area you can see while in the cockpit.
Now operate the LEFT turn signal and/or Hazards.
Does the test bulb exhibit the same problem the Indicators exhibit?
Happy Racing!
Happy Racing!
MikkoV
Sep 9, 2015 04:25 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
