speedo quits, vss code, tach runs 2X too fast, temp pegs on '88 IROC convert
my speedo quit (got vss code), tach started running double what it should, temp gage starts normal, then runs "hot" when it isn't really hot. This all happened at the same time, and I suspect a common cause. any ideas on what might cause all these problems to start at the same time?
John
Asheville, NC
John
Asheville, NC
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Gage Rage
A bad ground at the dash is a common cause for multiple gages to go crazy simultaneously, so check the grounds first.
Then make sure the two connectors on the back of the dash are still seated.
Another cause is a broken trace on the circuit board in the dash.
A VSS code can be set by other reasons than a bad or disconnected VSS.
Happy Racing!
Make Noise, Turn Left, Repeat
Happy Racing!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedo quits, vss code, tach runs 2X too fast, temp pegs on '88 IROC convert
JamesC
Re: Gage Rage
I found the body ground near the battery, and the braided one that bolts to firewall. I cleaned and reconnected those, although they were in perfect shape. Any idea where the ground for the dash is?
John
John
Happy Racing!
Happy Racing!
Transmission: 765R4
Grounds 4 Dash-missal
The black ground wires come out of the dash connectors and go to the ‘Convenience Center’ bracket.
The Convenience Center is located behind the knee bolster.
The Convenience Center contains a flasher among other parts (just to help you identify it).
Happy Racing!
If You’re Passed By Your Own Tire On The Track, It’s Time For A Pit Stop
Happy Racing!
