Dome Light doesnt work
Old Mar 8, 2011 | 10:00 AM
justcallmeclassy's Avatar
Car: 1992 Camaro RS Z03 T-Top
Engine: L98 with TBI
Axle/Gears: 2.73...
A few days ago my dome light and rear view mirrror lights stopped working. Im pretty sure its just a fuse, but a lot of my fuses aren't labeled for some reason...... so could somebody help me figure out which one it is? I did a search but couldnt really find what i was looking for. Its a 92 RS, thanks
Old Mar 8, 2011 | 10:46 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Dome Light doesnt work
Here's a wiring diag with your fuse box:
http://www.austinthirdgen.org/mkport..._continued.gif
All other wiring diags: http://www.austinthirdgen.org/index.php?pid=19
Might be a door switch stuck closed - they can rust and get stuck. The door switches control the ground side, not the power side of the circuit. Door closed means switch is open and no ground for the lights - door open means switch is closed and the lights get a ground.
Old Mar 8, 2011 | 12:01 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
If it's the fuse, there are quite a few things that won't work either. Cigarette lighter (most likely culprit to blow the fuse), horn, electric door locks (if equipped), electric hatch release (if equipped), under hood light, to name a few.
Old Mar 8, 2011 | 02:17 PM
Axle/Gears: 2.73...
Its funny because I have all of these things equipped, but none of them work at the moment haha all work in progress
Old Mar 8, 2011 | 02:18 PM
Axle/Gears: 2.73...
Thanks a lot ill check this out immediately
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
justin57
Aug 20, 2015 07:05 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
