Starting issue (Starter not turning)
Old Mar 6, 2011 | 06:43 PM
notoriouscamaro's Avatar
Car: 92 RS 5 speed
Engine: 5.0L TBI
Axle/Gears: 9 bolt rear
Hey guys,
Sorry if this has already been talked about recently but I'm currently stumped. I have a 92 RS 305 TBI 5 speed that is not starting. The car is not turning over(the starter is not spinning).
The car push starts fine and the fuel pump is humming in the on position but when I go to crank it it does not spin over. SO since I can push start it, I know im not having an issue with VATS. Right?
I tried jumping the neutral safety switch with some wire but that didnt help. I tested continuity on the neutral/clutch safety switch and its fine. Today, I hooked up my multimeter to the safety switch wire and got voltage. I also just changed the starter relay. Since I am getting power to the safety switch does that mean my ignition is working? (The switch/cylinder). I am thinking the starter is bad right now but cant get under the car right now to test the voltage and jump the solenoid.
Just want to clear some things up. Thanks in advance
Old Mar 6, 2011 | 06:59 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Starting issue (Starter not turning)
Starter will have a purple wire to it, on a terminal all on it's own. Grab a 10gauge wire, and put 12v+ directly from battery to where that purple wire connects - if the starter spins it's good. Then trace back to the NSS, relay, and ignition switch.
Here's a troubleshoot guide: http://www.austinthirdgen.org/index.php?pid=38
Wiring diags: http://www.austinthirdgen.org/index.php?pid=19
Lots of 92 diags at bottom of that page as well - great stuff there!
Old Mar 6, 2011 | 09:29 PM
Car: 92 RS 5 speed
Engine: 5.0L TBI
Thanks! Ill let you know what happens.
Old Mar 7, 2011 | 09:32 PM
Car: 92 RS 5 speed
Engine: 5.0L TBI
Ok, so I jumped the solenoid (purple terminal) from the battery and nothing. I didnt have the keys in the ignition though..would vats prevent the starter from turning?
Old Mar 7, 2011 | 09:40 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
sounds like it's time for a new starter, jumping it should at least cause a click. Give it a nice smack with a hammer if you haven't tried already.
Old Mar 7, 2011 | 10:15 PM
Car: 92 RS 5 speed
Engine: 5.0L TBI
Tried the hammer.. looks like its the starter, at least its an easy job. Hopefully this fixes it!
Old Mar 8, 2011 | 09:37 AM
Car: 1992 RS
Engine: Carbed 350
You HAVE to have the key on! Sorry, I neglected to mention that. So, retest with key on.
Old Mar 8, 2011 | 10:05 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
You don't have to have the key on to test it. Putting 12 volts to the terminal where the purple wire connects will push the pinion out and turn the engine over. The car won't start without the key being on but it will crank if the starter is good.
Old Mar 8, 2011 | 03:08 PM
Car: 92 RS 5 speed
Engine: 5.0L TBI
That's what I was thinking. Thanks.
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
86Base
Aug 8, 2015 01:34 PM
92projectcamaro
Aug 6, 2015 01:20 PM
