Getting through the firewall
Old Mar 10, 2011 | 12:32 PM
1991rscamaro1's Avatar
Car: 1991 Camaro RS
Alright, i'm wiring a button into my car. I need to get 2 wires into the cab from the engine compartment. Took some panels off from under the dash to get a better view, and I cannot find where to snake these wires through. If possible, is there any place to get wires through without drilling a new hole? This should be a quick wiring process and I don't want to have to go out of the way for it. Any tips, and tricks? Thanks a lot! It's a 1991 rs if that helps?
Old Mar 10, 2011 | 02:56 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Getting through the firewall
Depends on which side. You can snake them through the passangerside were the ecm wiring harness comes through, but it might be a tad difficult to run them down to the hole.
Old Mar 10, 2011 | 03:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There's plenty of area close to the ECM wiring on the pass side to drill a new hole - just make sure you use grommets or something (this is where I ran my amp wire).
There's also a hole somewhere where the antenna wire runs through, and where the wiring for a power antenna would be (if you had one), but I don't know exactly where that is - maybe trace the antenna wire and see where it runs through.
Old Mar 10, 2011 | 03:49 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
There should be a factory cut hole right behind the brake pedal.At least there is on my car.As already mentioned make sure you use a grommet.
get down low by the floor board and look back to the firewall.it should be there.You should be able to access it from the engine bay underneath the brake booster.
Old Mar 10, 2011 | 04:11 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
There are a few holes you can use....there is a grommet hole to the right of the brake booster, that is for the fog light harness, there is a grommet hole under the brake booster, that is for the cruise control harness, of which you should be able to get a rubber plug to fill the hole up with the wire running through the rubber grommet. Then there is the antenna grommet is usable on the passenger side under the fender, it has room for a few smaller wires, or a small amp wire, nothing bigger than 8 gauge amp wire though.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
djmarch
May 8, 2016 11:32 AM
mfp189
Sep 27, 2015 09:25 AM
armybyrd
Sep 21, 2015 10:28 PM
gta892000
Sep 16, 2015 12:40 AM
