Battery Charging Question... Real quick!
Old Mar 18, 2011 | 11:49 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I was driving and the gauge said around 12ish volts, then I noticed my lights got brighter and the gauge bounced around 14 volts, and would kinda dip down and up a bit, then eventually go back to around 12.
The Gauge usually reads a steady 12 volts.
Is this a sign that my alternator is going out? Or is it a bad ground?
Old Mar 19, 2011 | 02:12 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Battery Charging Question... Real quick!
Nobody?
Old Mar 19, 2011 | 02:40 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The probelm you describe is typical of worn alternator brushes. May also be a failing regulator. However, before i go buy a replacement, I would check the Battery cables and connections, and all wiring and connections to the alternator. Note: the alternator grounds through its frame to the engine. The wires to the unit are all power, they should each illuminate a test light with the key on, engine off.
Old Mar 19, 2011 | 09:02 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Mine did that, lights flickered a bit and gauge moved some - alternator was overcharging. Any auto parts store can test alternator in the car for free (AZ/Advance/Oreilly/etc.) - go have it tested.
Old Jan 19, 2020 | 07:19 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
wrong hole
kattotonic
Jan 12, 2015 09:04 AM
grove
Jul 10, 2014 08:24 AM
Mr.Dz28
Mar 12, 2011 08:09 PM
KYLE87
Jun 7, 2007 08:29 PM
