are all 90+ firebirds pre wired for fog lights
Old Mar 23, 2011 | 06:48 AM
Chris67rs's Avatar
Car: 91 Firebird Formula WS6
Axle/Gears: 3.27 9 bolt
my 91 did NOT have fog lights from factory, I have added them from another 91 doner at the junkyard. i wired them up ghetto style and they work on a pole switch. but I want to use the factory triple switch in the center (trunk release/fog lights /rear defroster) I have the info on which wire to which, but saw many posters in my searches say that they had the wires already.
when i hooked fog lights up I didnt see any factory plugs under the nose. where would those be hidden? and where would i find the ones for the inside. , oh and wheres the relay at??? my assembly manual says under dash but I thought they were under hood near fuel pump relay. I have a Fog light fuse (empty) in the fusebox too.
thx.
Old Mar 24, 2011 | 06:02 PM
Pocket's Avatar
Car: 91 Trans Am
Re: are all 90+ firebirds pre wired for fog lights
The light harness under the hood could be had with and without fog lights
The dash harness came with all options ready to go. Pull the switch panel above the radio pod and check for the missing connector for the fog light rocker switch. Beware with the option deleted, the relay body is likely to be missing as well leaving only an empty socket and an empty fuse slot
Old Apr 8, 2011 | 08:40 PM
Chris67rs's Avatar
thanks for the tip. mine has nothing . the dash harness is a no go. i even untaped some of the main and nothing, I purchased the centerpiece with all 3 switches, it originally had the two, trunk and r def. so im screwed. gotta hook it up old school way (wire it manually)
Old Apr 8, 2011 | 09:04 PM
Pocket's Avatar
Car: 91 Trans Am
Yours is an export car. Those are... interesting
jaridjohn
Jul 8, 2024 03:49 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
tnrednneck
Aug 13, 2015 08:57 AM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
