multiple engine wires from passenger side
Old Mar 24, 2011 | 11:41 AM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
I am unsure where all of these wires go. I am guessing the car was carbed or something. I found these wires all bunched up and taped off. Is there a way to unplug the entire set of wires or should i just figure out where they go and hack away from another car? thanks
Old Mar 24, 2011 | 11:57 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: multiple engine wires from passenger side
there is only one main harness on the passenger side, and its everything that's related to the engine computer. you could try to depin them, but the bulkhead is potted (epoxy filled), so its not an easy chore without possibly doing damage to other wiring
Old Mar 24, 2011 | 12:57 PM
Car: 91 RS T-top
Thanks. So i pulled the harness from both cars now what would be the difference in automatic and manual? would it be just the transmission wires?
first pic is manual wiring
second pic is automatic wiring
Old Mar 25, 2011 | 04:06 PM
Car: 91 RS T-top
No wire guru on this? Guess ill figure it out and keep this updated for future reference.
Old Mar 26, 2011 | 06:25 PM
Pocket's Avatar
Car: 91 Trans Am
Autos have the brake switch wire from the C100
Manuals have the back-up light connector from the C100 and no brake wire
Did your LO3 actually run with all those wires chopped?
Old Mar 27, 2011 | 01:14 PM
Car: 91 RS T-top
no i bought the car without a engine im installing a L03 now
Old Mar 27, 2011 | 01:20 PM
Car: 91 RS T-top
ok the wires running to the transmission. Which wire isnt used?
This is the automatic plug with three wires
This is the manual with two wires
Old Mar 27, 2011 | 01:26 PM
intruder's Avatar
the asuto should have 2 plugs the one in the 1st pic is to the torgue converter lock up switch ther should be another plug that would go the speed sensor. the plug for the manual it the speed sensor
Old Mar 27, 2011 | 01:28 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The 3 wire plug is for converter lock-up. The 2 wire is the reverse light switch plug (vss is a purple and yellow wire).
Reverse light switch is on the auto shifter along with the park-neutral switch.
Old Mar 27, 2011 | 03:30 PM
Car: 91 RS T-top
OK there are two plugs for auto and two plugs for manual. The first pic is auto. A total of 5 wires three on one plug two on the other. The three wire plug has a wire I need to delete or ground off or something which wire (color) do I do this to and what needs to be done to it.
First pic is auto
This is manual
Old Mar 27, 2011 | 04:32 PM
deadbird's Avatar
Engine: TPI 305/ v6
Old Mar 27, 2011 | 07:40 PM
Car: 91 RS T-top
thanks. I am guessing the tan and black should be deleted.
Ikes 91Z
Dec 9, 2015 03:49 PM
LittleFranks
Aug 20, 2015 03:55 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Elliswon
Aug 10, 2015 12:33 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
