1990 Firebird third brake light doesn't work!
Old Apr 3, 2011 | 11:52 AM
JimRockford's Avatar
Any advice?
I have cleaned the hatch contacts,checked the bulbs and the third brake light in the spoiler still doesn't work.
Which fuse do they run off?
My mirror lights dont work either,but my dome light,cigarette,power hatch release and everything else does.
Old Apr 4, 2011 | 03:32 AM
kcid_n_ysup69's Avatar
Car: 89 formula
Re: 1990 Firebird third brake light doesn't work!
how long has it been not working? i beleive there is a pigtail connector somewhere under there. could have gotten disconnected
Old Apr 4, 2011 | 09:53 PM
It has not worked since I have owned the car.
Where is the connector you are talking about?
Old Apr 4, 2011 | 10:43 PM
Car: 89 formula
remove the plastic cover it should be attached to the contacts in order to power it when you hit the brakes i beleive its a pigtail w/ 2 or 3 wires, should be around all your hatch motor wires but should be attached to the contacts. my interiors gutted i removed the hatch motor and wires snapped a couple pics for you, the wires im holding is where your wires should be connected. if they are connected it could be something else. the contacts may be clean but if theyre not making a good contact they might not light up
Attached Thumbnails 1990 Firebird third brake light doesn't work!-sam_0503.jpg   1990 Firebird third brake light doesn't work!-sam_0504.jpg   1990 Firebird third brake light doesn't work!-sam_0505.jpg
Old Apr 16, 2011 | 01:41 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
are there suppose to be wires running up to it? mine doesnt work either, the contacts inside near the bulbs are good, just cant seem to figure it out
Old Jun 6, 2011 | 09:22 PM
Pat1990GTA's Avatar
Car: 1990 Trans Am GTA
Engine: 383 HSR Profiler heads
Have you solved your brake light problem yet?
Its most likely your contacts on your hatch not lining up with the contacts on the car...these third gens are bad for there rear hatch alignment
To check where they are making contact put a bit of grease on the hatch contacts and close the hatch. Reopen to see where they made contact. Hope this helps!
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
zeitghaist
Aug 18, 2015 07:33 AM
Omega
Aug 10, 2015 12:46 PM
