i unplugged lighter, taped it off. took out toggle switch previous owner had for fan. put everything back the way it came from factory. before i did all that the acc fuse blew i bout 5 mins. now light stays on and fuse dont blow. but i still get no acc at radio harness. book shows it the larger yellow one? so that the one ive been testing.
Radio has a fuse of its own, not necessarily tied into the ACC fuse.
i havent even hooked up radio. i just tested for power at yellow wire w/ test light with key turnt to acc.
well my mistake. i thought the thicker yellow wire was the accessory wire, but turns out its the thinner one.
Quote:
where in the stock ac delco radio is the fuse located? this is out of a 85 firebirdOriginally Posted by camaronewbie
