charging issues
Old Apr 12, 2011 | 11:32 PM
memphis1967's Avatar
Car: '84 Z28
Axle/Gears: 98 T/A 10 bolt. Auburn, 3.42
charging issues
Ok, working with an '84 z28, used to have a CC carb, swapped in an old 350 with a basic carb, so we don't need the the ECM or some of the plugs on the wiring harness (i'm assuming). I 'm also assuming that there used to be a fan relay somewhere that is now gone. The alternator is not charging. We have a new alternator, and a good battery. The alternator has the stud on the back connected straight to the battery. The plug for the alternator has a black and a dark green wire. With a ohm meter, the black one goes to ground (or the gauge?), the dark green one does nothing, no ground, no power key on or off. I found another plug in the wiring harness with 3 male spade terminals, one of which has continuity to the alternator plug green wire. Did this go to the electric fan relay at some point? There was a resister between the two terminals that go into the alternator, the black and green wire. My questions are, what does the resister do, and where do I need to connect the green wire?
Old Apr 13, 2011 | 02:32 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: charging issues
wiring diags might help: http://www.austinthirdgen.org/index.php?pid=19
TrevinE
Sep 14, 2015 03:20 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
TheExaminer
Sep 7, 2015 08:34 AM
Slush92RS
Sep 2, 2015 08:56 PM
