2nd Rear Defrost Switch Shorting Out!!!
Old Apr 20, 2011 | 09:45 PM
TrueIroc's Avatar
Car: 1989 IROC-Z 100% Original
Engine: 5.0 TPI
Axle/Gears: 3.08
Rear Defrost Switch Blowing! 2nd one!!
On the day I bought my Iroc, I was driving home and I hit the Rear Defrost Button. It was working fine. I turned it off.. then turned it back on. All of a sudden there was a surge the volts dropped, lights dimmed, and the rear defrost switch blew. I was like really....
I checked all the fuses and they're good. So I figured just the rear defrost switch blew. I bought another rear defrost switch, # 14029595 installed it and I didn't even get to turn it on and it blew. As I plugged the harness into the new defrost switch I heard a little pop and I was like..No. I clicked it to go on and nothing, no defrost light. I tried again and nothing. The 2nd rear defrost switch blew as soon as I plugged it in. Why? I took it out and smelled the 5 metal pronges and I could smell a burnt smell.
I'm guessing I have a short somewhere and an open circuit? I looked up and down the rear defrost wires on the hatch and didn't see anything wrong. Has this ever happened to anyone? Where should I start looking for a short? I'm not buying a 3rd defrost switch until I diagnose where the short is first.
Any thoughts??
Old Feb 13, 2012 | 08:36 PM
Memphisfbody's Avatar
Car: 1989 IROC-Z
Engine: 5.7 TPI
Transmission: Automatic
Re: 2nd Rear Defrost Switch Shorting Out!!!
Did you every find your defrost issue, mine does the same thing.
Old Feb 28, 2012 | 04:12 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Lost Defrost
It sounds like there is a short to ground on the +side of the circuit.
Therefore inspect the
purple wire with a
white stripe coming out of the switch.
With the car totally turned off, unplug the heavy wire going to the rear window grid on the
+side, then use an ohmmeter to determine if the wire is shorted to ground.
It also sounds like the circuit breaker which protects the switch is defective or has been bypassed.
You can check for proper operation of the breaker by removing it and connecting an adjustable power supply to see if it trips above 30 amps.
If you don’t have access to the aforementioned test equipment just replace the breaker, making sure the PO didn’t bypass it.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is In The Air
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
AkDrifted
Aug 17, 2015 07:45 PM
dhonda200
Aug 11, 2015 11:50 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
